Add InForm web service locations
Web services are used to send discrepancies from DMW to InForm.
When created in the Administration page, they are available for use in the appropriate InForm study clinical data model. Alternatively, they can be created and edited in the clinical data model.
  1. Click Shows a computer monitor Navigation from the navigation bar and then click Administration.
  2. Make sure the Data Sources tab is selected, then click the Web Service Locations subtab.
  3. Click Icon is a plus sign.Add and select Add InForm WSL or clickIcon shows a pencil.Modify to update an existing web service location.
  4. Enter Web Service Location attributes.
    • Name: Enter any name for the web service location.
      Tip:
      Include the study name and lifecycle stage in the name to make it easy for the study configurator to select.
    • Web Service URL: Enter the WSDL URL for your InForm adapter.
      http://your_InForm_adapter.your_company.com/InFormAdapter/Discrepancy/DiscrepancyService.svc
    • Authentication Trial Name: Enter the study name exactly as it appears in the URL.
    • SSO Organization: For an on-premise installation, do not enter anything here. Doing so will cause harm.
      If your InForm installation, specifically the InForm Adapter, is hosted by Oracle, enter the organization associated with the DMW_QUERY user as provisioned for Single Sign-On use.
    • Username: The name of the account set up for authenticating DMW web service transactions. See Create required InForm users for details.
      The suggested name is DMW_AUTH.
      • The Username and Password fields are not displayed if DMW is installed using HTTP, not HTTPS.
      • Do not use spaces or special characters other than underscore (_) in the username or password.
    • Password: Enter the password required for the same user account. The system encrypts the password.
  5. Click Test Connection to test without saving, or Test and Save.
