Oracle LSH Object Operations
- Load Set Instance: Modify
 - Load Set Instance: Modify Val Status to QC
 - Load Set Instance: Modify Val Status to PROD
 - Table Instance: Modify
 - Table Instance: Remove
 - Table Instance: Modify Val Status to QC
 - Table Instance: Modify Val Status to PROD
 - Work Area: Create Table Instance
 - Work Area: Create Load Set Instance
 - Work Area: Modify
 - Work Area: Modify Val Status to QC
 - Work Area: Modify Val Status to PROD
 - Work Area: Deploy (Install)
Parent topic: Clinical Data Models and Query Builder
