Run the Driver Script
The driver prompts for all required input parameter values and calls the other scripts as required.
                     Log into SQL*Plus with an account with DBA privileges.
                     Go to the directory that contains the downloaded scripts.
                     Execute DMWInFormInstall.sql. The script prompts for: - A name to give the log file.
- TNS name or connect string for the InForm database. If you enter the connect string, do not enter any spaces.
- systemor other DBA username and password.
- Name of the Oracle DMW Admin account to be used or created for the purpose of giving privileges to the Oracle DMW read-only access account. The system creates the account if it does not already exist.
- Name of the Oracle DMW read-only access account to be used or created. The system
                           Tip: Do not use spaces or special characters other than underscore (_) in the username or password.
- Passwords for both accounts. If the accounts are new, the script prompts you to confirm each password. If the accounts already exist, you must enter a password, but the system does not change the existing password. It proceeds to create or update the packages owned by the schema.
- If the read-only access account is new, the script also prompts for a tablespace name. It then creates a tablespace on the InForm database to be used for the integration with Oracle DMW and creates or updates all Oracle DMW objects in this tablespace.
Parent topic: Create required Oracle accounts
