Copy a custom listing
  1. After you select a study, click Data Management.Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Custom Listing Manager from the drop-down menu to open the Custom Listing Manager tab.
  3. From the Custom Listings header in the left panel, click More Actions.More Actions, then click Copy Custom Listings.Copy Custom Listings.
  4. Select a project (or other study grouping).
  5. Select a model.
  6. Select one or more custom listings within the model.
  7. Click OK. The system searches the current model for the tables and columns that the selected custom listings read from.
    • If the tables or columns do not exist, the Copy operation fails with an error message.
    • If they exist but are marked Not Used in the transformation that writes to the model, the system copies the listings as disabled.
