Create discrepancies
To create a discrepancy on a data item:
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings, Custom Listings, or VC Listings. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. In the appropriate row, select one or more data items where you want to create a discrepancy. (You can select multiple data items if they all have the same issue.)
    Tip:
    To select multiple data items, press the Shift or Ctrl key while you select items.
  6. Right-click and select Create Discrepancy. The Create Discrepancy dialog box opens.
  7. For the State, select Open (definitely a discrepancy) or Candidate (possibly a discrepancy).
  8. In the Discrepancy field, enter details about the discrepancy (required). Then, fill in the remaining optional fields if necessary (Category and Action you want taken [for example, Ready to Send, Send to Spreadsheet, Needs Review]). To include a phrase set by you (for example, your name), select Append User Name.
    These optional fields may already be populated with default values. You can overwrite them if necessary. For more information about how these default values are configured, see Create and manage discrepancy default values in the Oracle DMW Study Setup Guide.
  9. Click Create. Each selected data item appears with a discrepancy icon. You can also see the discrepancy icon in the second column of the listing. For details on the discrepancy icons, see View discrepancies in the Listings page.
