How do I know if any filters are applied?
You can determine if the Listings or Discrepancies pages use filters by looking at the Filter field at the left of the navigation bar. For example,
  • If the page includes filtered data, the Filter field appears as On:Filter On.
    If you select the drop-down for the field, you see the toggle switch show blue with a white circle to the right when the page uses one or more filters: Enabled.
    You also see a list of any filters used, including advanced filters. For example, if you used the Site or Discrepancy State filter, you see it listed as an applied filter in the drop-down list.
  • If the page does not include filtered data, the Filter field appears as Off: Filter Off.
    If you select the drop-down, you see the toggle switch show gray with a white circle to the left: Disabled.
