Cascade Not Used from source to target
If the source model contains columns and tables not used, you can
                        extend the Not Used status in the source through to the target tables so
                        they do not appear in the transformation.
                     After you select a study, click the Study Configuration icon  from the navigation bar to open the Clinical Data Model tab. from the navigation bar to open the Clinical Data Model tab.
- Click the Transformation tab to view the source and target tables.
- Check if the source has tables or columns not used.
- Select Cascade Not Used from the Actions menu in the title bar of the Transformation tab.
Parent topic: Mark target tables and columns as Not Used
