Create public filters
Filters allow data reviewers to specify the data and discrepancies to view. While data reviewers are free to create and use their own filters, we recommend you create a set of common public filters that data reviewers can use or modify to fit their needs.
Tips:
                        Create a set of standard public filters.
                        Do not create so many that it is hard for users to find their own filters.
                        Name each public filter descriptively so users know if it is useful for their purposes.
