Manage Custom Programs & Static Functions in Oracle DMW
You can view, modify, and add custom programs and static functions in the Oracle DMW user interface by accessing Programs from the Navigation button in the toolbar.
The Custom Programs & Static Functions interface displays a list of all Custom Programs configured for your environment. Selecting the Static Function radio button refreshes the page to display all existing Static Functions. You can use the filters in the upper right portion of the page to search for specific programs and functions.
The Refresh button can be used to synchronize the list of programs or functions with the database.
- Create a Custom Program in Oracle DMW
You can define a custom program directly in Oracle DMW by accessing Programs from the Navigation menu. - Create a Static Function in Oracle DMW
You can make a static function that can be included in custom programs in Oracle DMW by accessing Programs from the Navigation button on the toolbar. - Modify Validation Status for a Static Function
You can change the validation status of a checked in static function from the hyperlink in the Validation Status column on the Custom Programs & Static Functions main page.
