Select Clinical One datasets for use in Oracle DMW
You can choose to include optional, non-clinical datasets from Clinical One in Oracle DMW from the Administration interface or during study configuration.
  1. Click Shows a computer monitor Navigation from the navigation bar and then click Administration.
  2. Make sure the Data Sources tab is selected, then click the Clinical One Datasets subtab.
  3. Select the datasets you want to include by default in DMW studies.
    Tip:
    Some tables are required for internal processing and cannot be deselected.
  4. Click the Icon is a floppy drive.Save icon.
