Check in Objects and Copy them into a Different Domain
Use this overloaded API to copy objects into a Domain and check them in if they are checked out, before copying.
Name
CDR_PUB_DF_DOMAIN.CopyObjectsIntoDomain
Signature
PROCEDURE COPYOBJECTSINTODOMAIN( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRBASEOBJCOLL IN OUT CDR_BASE_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_CHECKINFLAG IN VARCHAR );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_CDRBASEOBJCOLL (Mandatory) This is a collection of CDR_BASE_OBJ_TYPEs.
For each object that you want to copy, initialize a CDR_BASE_OBJ_TYPE and then extend the
collection.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of
CDR_BASE_OBJ_TYPE and contains basic naming details about the Domain into which you want
copy objects.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, and OBJECT_VERSION_NUMBER).
- PI_CHECKINFLAG (Mandatory) Enter $YESNO$YES if you want to check in the copied objects, if they are checked out, and $YESNO$NO if you do not want to check in the copied objects.
Parent topic: Define and Modify Domains
