Check Out a Validation Check Batch
Use this API to check out a validation check batch.
Name
DME_PUB_VALIDATION_CHECK.CheckoutValidationCheckBatch
Signature
PROCEDURE checkoutValidationCheckBatch (P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PIO_NAMING IN OUT NOCOPY CDR_NAMING_VERSION_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_NAMING (Mandatory). This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Validation Checks
Batch that you want to check in.
The following attributes are required:
- COMPANY_ID
- OBJ_ID
- OBJ_VER
- PI_COMMENT (Optional). Enter the reason you are checking out the Validation Check Batch.
Parent topic: Create and Modify Validation Checks and Batches
