Create a Binary Output
Use this API to create a binary output object.
Name
CDR_PUB_EXE_EXTERNAL.CreateBinaryOutput
Signature
PROCEDURE CREATEBINARYOUTPUT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_NCOMPANYID IN NUMBER, PI_VFILENAME IN VARCHAR2, PI_VDATA IN RAW := NULL );
Parameters
This API has standard parameters (see "Standard Parameters") and the following parameters:
PI_NCOMPANYID (Mandatory) Enter Company Id.
PI_VFILENAME (Mandatory) Enter the File Name.
PI_VDATA (Optional) Enter the RAW input to stream up the output.
Parent topic: Create and Execute Output LOBs
