Create a Temporary Blob
Use this API to create a temporary BLOB in a BLOB Table. Call this API before you upload Columns or Table Descriptors using the UPLOADOPERATORCOLUMNS API for a SAS or CPORT file, or before creating a Table for a SAS dataset.
Name
CDR_PUB_DF_TABLE.CreateTempBlob
Signature
PROCEDURE CREATETEMPBLOB( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_TMPBLOBOBJ IN OUT CDR_TEMP_BLOBS_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_TMPBLOBOBJ (Mandatory) This is parameter of table type CDR_TEMP_BLOBS_OBJ_TYPE that contains information about the BLOB.
The required attributes are: FILE_NAME, FILE_BLOB
Parent topic: Create and Modify Tables
