Get Attribute Values for Namespace Objects
Many APIs require internal IDs for the namespace object of the object you are creating. Use Get a Naming Version Object. to get these details. However, you must first determine what the namespace object is, using the object ownership diagram and explanation in the Oracle Life Sciences Data Hub Application Developer's Guide or Oracle Life Sciences Data Management Workbench Study Setup Guide, then query for the namespace object ID and object version using its name and its namespace's name and object type, in CDR_DF_NAMING_V.
Parent topic: Tips
