Get Checkout Properties
Use this API to retrieve the checkout status and implicit checkout property of a specified object.
Name
CDR_PUB_DF_NAMING_UTIL.GetChkoutProp
Signature
PROCEDURE GETCHKOUTPROP( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_COMPID IN NUMBER, PI_OBJID IN NUMBER, PO_CHKOUTSTATUS OUT VARCHAR2, PO_CHKIMPLPROP OUT VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_COMPID (Mandatory) Enter the COMPANY_ID of the given object.
- PI_OBJID (Mandatory) Enter the OBJ_ID of the given object.
- PO_CHKOUTSTATUS This is an output parameter. It returns the checkout status of the given object
- PO_CHKIMPLPROP This is an output parameter. It returns the implicit checkout property of the given object.
Parent topic: Get Data from Object Naming Tables
