Modify a Domain
Use this API to modify a Domain.
Name
CDR_PUB_DF_DOMAIN.ModifyDomain
Signature
PROCEDURE MODIFYDOMAIN( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Domain and enter new values for the attributes you want to modify. The COMPANY_ID, OBJ_ID and OBJ_VER of the domain to be modified should be initialized.
Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION. UPDATEVALSTATUS and CDR_PUB_DF_NAMING. UPDATEVERSIONLABEL.
Parent topic: Define and Modify Domains
