Modify an Execution Setup Parameter
Use this API to modify the parameters of an Execution Setup.
Name
CDR_PUB_DF_EXECUTIONSETUP.ModifYesParameters
Signature
PROCEDURE MODIFYESPARAMETERS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_PARAMETERCOLL IN OUT CDR_PARAMETER_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_PARAMETERCOLL (Mandatory) This is a collection of cdr_parameter_coll. Enter the values for parameters you want to change.
The attributes you can change are: read_only_flag_rc, mandatory_flag_rc, and visible_flag_rc. Enter $yesno$yes for yes, and $yesno$no for no.
Parent topic: Create and Modify Execution Setups
