Modify a Planned Output
Use this API to modify an existing Planned Output.
Name
CDR_PUB_DF_PLANNED_OUTPUT.ModifyPlannedOutput
Signature
PROCEDURE MODIFYPLANNEDOUTPUT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_POUTOBJTYPE IN OUT CDR_PLANNEDOUTPUT_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Planned Output.
- PI_POUTOBJTYPE (Mandatory) This is a parameter of table
CDR_PLANNEDOUTPUT_OBJ_TYPE that contains attributes specific to Planned Outputs. Enter
values for the Planned Output and enter new values for the attributes you want to modify.
You can change the name or description of a Planned Output.
Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION.UPDATE VAL STATUS and CDR_PUB_DF_NAMING.UPDATEVERSIONLABEL.
Parent topic: Create and Modify Planned Outputs
