Modify a Variable
Use this API to modify a Variable definition or instance.
To modify a Variable definition, you must first check it out.Name
CDR_PUB_DF_VARIABLE.ModifyVariable
Signature
PROCEDURE MODIFYVARIABLE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_NAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_VARIABLE IN OUT CDR_VAR_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_NAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes. Initialize the attributes COMPANY_ID, OBJECT_ID, and OBJECT_VER.
- PI_VARIABLE (Mandatory) This is a parameter of table type CDR_VARS_OBJ_TYPE. Provide values for the attributes you want to modify.
Parent topic: Create and Modify Variables
