Remove a Join Column
Use this API to remove one or more Columns from a Join.
Name
CDR_PUB_DF_BUSINESSAREA_JOIN.RemoveJoinColumns
Signature
PROCEDURE REMOVEJOINCOLUMNS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BUS_JOINCOLUMNS_COLL IN OUT CDR_BUSAREA_JOIN_COLS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_BUS_JOINCOLUMNS_COLL (Mandatory) This is a collection of CDR_BUSAREA_JOIN_COLS_TYPEs. For each Join Column that you want to remove, initialize a CDR_BUSAREA_JOIN_COLS_TYPE and then extend the collection.
The following attributes are required: COMPANY_ID,JOIN_OBJ_ID,JOIN_OBJ_VER,TD_COL_COMPANY_ID,TD_COL_OBJ_ID,FK_TD_COL_COMPANY_ID,FK_TD_COL_OBJ_ID,POSITION.
Parent topic: Create and Modify Business Area Joins
