Remove a Variable
Use this API to remove an existing variable object.
Name
CDR_PUB_DF_VARIABLE.RemoveVariable
Signature
PROCEDURE REMOVEVARIABLE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_NAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_NAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes. Initialize the attributes COMPANY_ID, OBJECT_ID, and OBJECT_VER.
Parent topic: Create and Modify Variables
