Reorder Validation Checks
Use this API to re-order validation checks.
Name
DME_PUB_VALIDATION_CHECK.ReorderValidationChecks
Signature
PROCEDURE REORDERVALIDATIONCHECKS (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PI_VC_MAP_COLL IN OUT NOCOPY DME_XFORM_MAP_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_VC_MAP_COLL (Mandatory). This is a parameter of collection type
DME_XFORM_MAP_COLL which is a table of DME_XFORM_MAP_OBJ_TYPE type. The
attributes required for this API from DME_XFORM_MAP_OBJ_TYPE are:
- COMPANY_ID
- OBJ_ID
- OBJ_VER
- EXECUTION_ORDER_NUMBER
Parent topic: Create and Modify Validation Checks and Batches
