Set a Customized Output Subtitle
Use this API to set a subtitle for individual RSE outputs.
Name
CDR_PUB_EXE_USER_UTILS.SetCustomOutputSubtitle
Signature
PROCEDURE SETCUSTOMOUTPUTSUBTITLE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_VFILEREF IN CDR_PLANNED_OUTPUTS.FILEREF%TYPE, PI_VVALUE IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_VFILEREF (Mandatory) Enter the file reference name of the Planned Output to which you want to assign the subtitle.
- PI_VVALUE (Mandatory) Enter the subtitle text.
Parent topic: Set Execution Statuses
