Set the Primary Flag to Yes
Use this API to set the Primary Flag attribute of a specified Source Code instance to Yes. If any other Source Code instance in the parent Program is currently set to Yes, the API resets its flag to No.
Name
CDR_PUB_DF_SOURCECODE.SetPrimaryFlagRC
Signature
PROCEDURE SETPRIMARYFLAGRC( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRSCREFBASEOBJTYPE IN CDR_BASE_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PI_CDRSCREFBASEOBJTYPE (Mandatory) This is a parameter of table type CDR_BASE_OBJ_TYPE. Enter values to identify the Source Code instance whose PRIMARY_FLAG_RC you want to set to $YESNO$YES.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
Parent topic: Create and Modify Source Code
