Submit an Execution Setup
Use this API to submit an Execution Setup.
Name
CDR_PUB_DF_EXECUTIONSETUP.SubmitExecutionSetup
Signature
PROCEDURE SUBMITEXECUTIONSETUP( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_EXECUTIONSETUP IN CDR_BASE_OBJ_TYPE, PI_CHANGEDSYSTEMPARAMETERCOLL IN CDR_SUBMISSION_DETAILS_COLL, PI_TICOLL IN CDR_SNAPSHOT_TABLE_COLL, PI_INCLUDEDOBJCOLL IN CDR_SUBMISSION_DETAILS_COLL, PI_CURRENTJOBID OUT VARCHAR2, PI_OUTPUTTITLE IN VARCHAR2, PI_OUTPUTDESC IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_EXECUTIONSETUP (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Execution Setup that you want to submit.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PIO_CHANGEDSYSTEMPARAMETERCOLL (Mandatory) This is a parameter of
cdr_submission_details_coll type.
You must provide values for the following system parameters: company_id (use CDR_DF_PUB_DEF_CONSTANTS.CURRENT_COMPANY_ID); submission_id (enter null); prref_id (enter -1), prref_ver (enter -1), parameter_ref_obj_id, and parameter_ref_obj_id. Query cdr_parameters on company_id, obj_id, and obj_ver to find values for the default_value attribute. Use this value to set the attribute parameter_value.
- PI_TICOLL (Mandatory) This is a collection of CDR_SNAPSHOT_TABLE_OBJ_TYPE.
- PI_INCLUDEDOBJCOLL (Mandatory) This is a collection of CDR_SUBMISSION_DETAILS_OBJ_TYPE that contains PRREF_IDs of Programs to include in the Execution Setup. For Report Sets and Report Set Entries, the user can include only selected Report Sets for execution. Enter only those PRREF_IDs.
- PI_CURRENTJOBID (Mandatory) Enter the JOB_ID of the Job that this Execution Setup submission created. This parameter is used to generate user's feedback.
- PI_OUTPUTTITLE (Mandatory) Enter a title for the output from this Execution Setup.
- PI_OUTPUTDESC (Mandatory) Enter the description for the output from this Execution Setup.
Parent topic: Create and Modify Execution Setups
