Understand Oracle LSH Functionality
To use Oracle LSH APIs, you must understand basic Oracle LSH functionality including:
- Object Ownership. You must create container objects before creating the objects they contain, because to create any object you must identify its namespace (parent or container) object. For example, begin by defining a Domain, then an Application Area, then a Work Area, and then create a Table definition in the Application Area and an instance of it in the Work Area. You can use a single API to create both the Table definition and an instance of it. For details, see "Object Ownership" in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Installation. You must create an instance of an object definition and install it before you can execute or store data in the object.
- Mapping. All executable objects must contain one Table Descriptor for each Table instance they read from and write to, and the Table Descriptors and Table instances must be mapped. For details, see "Defining and Mapping Table Descriptors" in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Checking Objects In and Out. You must check objects out to modify them and check them in before you install and use them. For details, see "Understanding Object Versions and Checkin/Checkout" in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Security. All objects require user group assignments to control user access. For details, see "Applying Security to Objects and Outputs" in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Classification. To enable objects to appear in the Reports tab of the user interface for end users to run them and view their outputs, you must classify them. Classifications can also be used in searching for objects. For details, see "Classifying Objects and Outputs" in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Validation. Objects should be validated according to your company policy whether they are created in the user interface or with APIs. For details, see "Validating Objects and Outputs" in the Oracle Life Sciences Data Hub Application Developer's Guide.
- Object-Specific Information. Further information on each object type is included in other chapters of the Oracle Life Sciences Data Hub Application Developer's Guide.
Parent topic: About APIs
