Generate the Discrepancy Differences Report
You can generate the Discrepancy Differences report from the Discrepancies interface to view any variances between discrepancies in Oracle DMW and the source system.
The Discrepancy Differences Report compares the data currently loaded into Oracle DMW with discrepancy data in InForm or Clinical One to highlight discrepancies that may
            need manual intervention. The results are available for download in an Excel
            spreadsheet, split into two sheets:
               - Discrepancy_Differences: Contains discrepancies where the text, state, or revision do not match between Oracle DMW and the source system.
- Missing_Discrepancies: Contains discrepancies that are missing from Oracle DMW but found in the source system.
To generate the Discrepancy Differences Report, click the Discrepancy
                Differences Report
                   icon above the Discrepancies grid. In the subsequent Discrepancy
                Differences Report pop-up, you can click Generate
                Report button to create a new Discrepancy Differences Report or download
            one of the previously-generated files.
Parent topic: Advanced: Run jobs and check history
