Create Data Source lswdbBC4JDS
Create data source lswdbBC4JDS as described. (For more information, see Oracle® E-Business Suite Software Development Kit for Java.)
The .dbc file referenced in the procedure came from the file you copied in Copy the Database Connection File.
To create data source lswdbBC4JDS:
In Step 5, enter values exactly as follows:
  • Name for the datasource: lswdbBC4JDS
  • JNDI Name: jdbc/lswdbBC4JDS
  • Database Driver: Oracle's Driver (Thin) for Instance connections.
    (Note that this driver is a non-XA driver.)
  • Driver ClassName: Accept the default name.
In Step 8, enter values for your environment:
  • Database name: dmwebspr (example name)
  • Hostname: your_hostname
  • Port: 1521
  • DB User Name: CDRBC4JINTERNAL
  • Password: your_password
In Step 10, enter values exactly as follows:
  • Driver Class Name:
    oracle.jdbc.OracleDriver (default)
  • Database User Name:
    dmwebs@oracle.com
