Deploy Discrepancies Export and Data Flow Diagram Modules
  1. Copy the services/dmw-dfd-app.ear and services/dmw-export-app.ear files to the tmp directory and delete the software directory.
    The tmp directory now contains dmw-dfd-app.ear and dmw-export-app.ear files.
  2. Open a shell window and set up the environment:
    source WL_HOME/server/bin/setWLSEnv.sh
    For example:
    source app/oracle/middleware/Oracle_Home/wlserver/server/bin/setWLSEnv.sh
  3. Change the directory to the tmp directory.
  4. Deploy dmw-dfd-app.ear and dmw-export-app.ear by entering the following command. If you stored the username and password in a configuration file, omit the username and password parameters.
    Deploy both the ear files on the same target where you have targeted the lswdbDfdDS and lswdbExportDS data sources.
    In the following command, replace the variable DMW_NEW_SERVER_NAME with the recommened new server name DMWServicesServer.
    java weblogic.Deployer -adminurl t3://host_name.your_company_domain.com:port_number -username WLS_USER -password WLS_PASSWORD -targets DMW_NEW_SERVER_NAME -deploy dmw-dfd-app.ear -name dmw-dfd-app
    java weblogic.Deployer -adminurl t3://host_name.your_company_domain.com:port_number -username WLS_USER -password WLS_PASSWORD -targets DMW_NEW_SERVER_NAME -deploy dmw-export-app.ear -name dmw-export-app
    If you had not created the DMW_NEW_SERVER_NAME (DMWServicesServer) due to any constraint, then deploy dmw-dfd-app.ear and dmw-export-app.ear by entering the following command:
    In the following command, replace the variable DMW_SERVER_NAME with the recommened server name DMWServer.
    java weblogic.Deployer -adminurl t3://host_name.your_company_domain.com:port_number -username WLS_USER -password WLS_PASSWORD -targets DMW_SERVER_NAME -deploy dmw-dfd-app.ear -name dmw-dfd-app
    java weblogic.Deployer -adminurl t3://host_name.your_company_domain.com:port_number -username WLS_USER -password WLS_PASSWORD -targets DMW_SERVER_NAME -deploy dmw-export-app.ear -name dmw-export-app
  5. Exit the shell by entering:
    exit
  6. Go to the WebLogic console screen to check that the deployments are successful.
