Rename the Existing "Clinical One Operational Data" Data Models
Execute the cdrc1suppdmrename.sql script to rename all the existing "Clinical One Operational Data" data models to "Clinical One Supplementary Data".
Run this script only if you are upgrading to Oracle DMW 3.4 and have studies loaded from Clinical One (using DMW-C1 integration) in any of the previous versions of Oracle DMW.
Follow these steps to run the script on a computer with an Oracle client that can connect to the Oracle DMW database server using SQLPlus:
  1. Download the file from $CDR_TOP/patch/115/sql/cdrc1suppdmrename.sql.
  2. Log in to SQLPlus (not SQLDeveloper) as the APPS database user.
  3. Invoke the script from your download directory:
    <download_directory>/cdrc1suppdmrename.sql
