Manage Work Areas in Oracle DMW
You can review Work Areas associated with a selected study on the Oracle DMW home page by clicking the Workareas for selected Study
Work Areas in Oracle DMW contain all of the object instances (Table Instances, Program Instances, etc) which
point to object definitions. Each data model in a study is associated with a different
work area for each lifecycle. After selecting a study on the home page, you can click
icon to load a new screen where you can view the Work Areas related to the
selected study. You can search by data model name to find specific Work Areas using the
search function in the upper right corner of the screen.
Clicking a row in the Workareas grid loads the instances in the Instance Objects Under: [Work Area Name](Version Number) section in the bottom half of the page.
- Install a Work Area in Oracle DMW
You can install Work Areas on the Workareas screen, accessed from the Workareas for selected Study icon on
the Home page after selecting a Study.
- View Work Area Install History in Oracle DMW
You can view the installation history and download log files for Work Areas associated with a selected study in the Workareas interface in Oracle DMW. - Remove Object Instances from a Work Area in Oracle DMW
You can remove an object instance from a Work Area on the Workareas interface in Oracle DMW.
Parent topic: Set up clinical data models
