Add users to user groups in Oracle LSH
The roles you add to a user group are available for the Group Administrator to assign to users within the group.
  1. Log in to Oracle LSH as the system administrator.
  2. Expand the Life Sciences Data Hub node in the main menu on the left or from the Navigator drop-down. Select User Groups.
    Or, if Oracle LSH is already open, go to the Security tab and select the User Groups subtab.
  3. Enter the name of the user group for which you want to add roles in the user group box.
    Or, to see all user groups, enter %.
  4. Click Go.
  5. Click the required user group.
  6. Click Add and Remove Role.
  7. Double-click on a role in the Available Roles column to move it into the Selected Roles column.
    You can also select multiple Roles by using Shift+click or Ctrl+click and use the arrows to move one, a few, or all at once to the column in the shuttle.
    You can change the order of the Roles using the Up and Down arrows on the right.
  8. Click Apply.
