Oracle LSH Object Operations
- Application Area: Create Work Area
- Domain: Create Program
- Domain: Create Variable
- Execution Setup: Modify Val Status to PROD
- Execution Setup: Modify Val Status to QC
- Execution Setup: Submit
- Program: Modify Val Status to PROD
- Program: Modify Val Status to QC
- Program: Modify
- Program: Remove
- Program Instance: Modify Val Status to PROD
- Program Instance: Modify Val Status to QC
- Program Instance: Create Execution Setup
- Program Instance: Remove
- Table: Modify Val Status to PROD
- Table: Modify Val Status to QC
- Table Instance: Modify Val Status to PROD
- Table Instance: Modify Val Status to QC
- Table Instance: BlindBreak
- Table Instance: ReadData
- Table Instance: ReadUnblind
- Table Instance: Remove
- Table Instance: Unblind
- Table: Modify
- Table: Remove
- Table: View
- Work Area: Create Program Instance
- Work Area: Create Table Instance
- Work Area: Deploy (Install)
- Work Area: Modify
- Work Area: Delete
- Work Area: Modify Val Status to PROD
- Work Area: Modify Val Status to QC
Parent topic: Transformations and Query Builder
