Create and Modify Validation Checks and Batches
This section contains the following public APIs:
- Create a Validation Check Batch
- Modify a Validation Check Batch
- Remove Validation Check Batch
- Update a Validation Check
- Install a Validation Check Batch
- Submit a Validation Check Batch
- Check In a Validation Check Batch
- Check Out a Validation Check Batch
- Undo Checkout For a Validation Check Batch
- Update Validation Status of a Validation Check Batch
- Upgrade a Validation Check Batch
- Remove Validation Check(s)
- Enable or Disable Validation Checks
- Reorder Validation Checks
- Update Risk Score
Apply the score to previously scored or un-scored pre-existing discrepancies.
Parent topic: Validation Checks
