Expand Default Listings, Custom Listings, or VC Listings.
Then, expand a clinical data model from the list.
Select a listing to open it.
In the appropriate row, select one or more data items where you want to create
a discrepancy. (You can select multiple data items if they all have the same
issue.)
Tip:
To select multiple data items, press the Shift or Ctrl key
while you select items.
Right-click and select Create Discrepancy. The Create Discrepancy dialog
box opens.
For State, select Open (definitely a discrepancy) or Candidate (possibly a discrepancy).
In the Discrepancy field, enter details about the discrepancy
(required). Then, fill in the remaining optional fields if necessary
(Category and Action you want taken [for example, Ready to
Send, Send to Spreadsheet, Needs Review]). To include a phrase set by you (for
example, your name), select Append User Name.
These optional fields may already be populated with default values. You can overwrite them if necessary. For more information about how these default values are configured, see Create and manage discrepancy default values in the Oracle Life Sciences Data Management Workbench Study Setup Guide.
In the Impact, Probability, and Non-Detectability fields, enter a risk score in the range from 1 to 10. The average risk score appears in the read-only Risk Score field.
Click Create. Each selected data item appears with a discrepancy icon.
You can also see the discrepancy icon in the second column of the listing. For
details on the discrepancy icons, see View discrepancies in the Listings page.
