Generate a blind break report
Generate blind break reports for the default listings.
You can generate the following three reports:
  • Table Blind Break Report
  • Data Model Blind Break Report
  • Blinded Instances Report
The data model level blind break report shows the blind break on only the latest version of each table in the data model.
  1. Select a study and click Data Management. Data Management in the navigation bar.
  2. Select Listings.
  3. Expand Default Listings.
  4. To generate a data model blind break report:
    1. Select a data model from the list.
    2. From the Action drop-down list, select Generate Data Model Blind Break Report.
    3. For the Activity Type, depending on your requirement, select the Job and/or Browse checkbox.
    4. From the Date Range drop-down list, select a desired value.
      If you select Custom, then select the date range.
    5. Click Generate Report.
    6. Under the Report Generation History, click on the report link to open the report.
      You can save the report to your local machine.
  5. To generate a blinded instances report:
    2. From the Action drop-down list, select Generate Blinded Instances Report.
    3. Click Generate Report.
    4. Under the Report Generation History, click on the report link to open the report.
  6. To generate a table blind break report:
    1. Select a table from the list.
    2. From the Action drop-down list, select Generate Table Blind Break Report.
