Use the Discrepancy Dashboard
The discrepancy dashboard is an interactive, graphic overview of the study's discrepancies, beneficial to data managers who need a quick, at-a-glance summary of a study's progress. Selecting a study from the left navigational panel displays the study's discrepancy dashboard in the center section of the page.
For details on selecting a study, see Select a study from the Home page.
The dashboard initially displays discrepancies across all countries and sites in a selected study. The total number of discrepancies within the study is shown in the right corner of the section, under Refresh. The discrepancies in the study are displayed as four different graphs: State, Origin, Site, Age, and Risk Score.
Using the filter selection options in the dashboard refines the discrepancies for all four of the graphs as well as the total discrepancy count on the dashboard within the selected parameters. When you use the filter fields, you can begin typing your filter criteria to narrow the results of the drop down lists. The following filter options are available:
  • Country: This drop down list displays all countries associated with the study.
  • Site: Selecting this field displays a drop down list with all sites associated with the study.
  • Category: Displays all categories your organization has created for discrepancies.
    Administrators can refer to Create categories for flags, discrepancies, and validation checks in the Oracle Life Sciences Data Management Workbench Administration Guide for more information about categories and discrepancies.
  • Validation Check Batch: To filter the discrepancies on the dashboard by validation check, you need to select a validation check batch from this drop down list. The dashboard will not refresh until you proceed to select a validation check in the associated Validation Check filter field.
  • Validation Check: This field is disabled until you select a Validation Check Batch. The Validation Checks listed here are filtered based on your previous Validation Check Batch selection.
Hovering over a data set in a graph (the Open bar of the State graph, for example) displays additional information such as the number of discrepancies.
Clicking a data set within any of the graphs on the discrepancy dashboard takes you to the Discrepancies interface, where the filters from the graph section have already been applied. For example, clicking the Manual section of the Origin graph takes the user to the Discrepancies page where the Advanced Filter has been set to "Discrepancy Origin = Manual". This pre-filtered data allows data managers to navigate to the discrepancies within the data set with a single click.
The time stamp in the upper right corner of the section shows when the data was last refreshed. If multiple users are actively working on a study or if your session has been idle, you may want to manually refresh the page by clicking Refresh..
Clicking Refresh triggers a job to update the data in the background. There may be a delay in displaying the refreshed data on the dashboard while the job processes.
For additional details about each type of graph, see the following topics:
