Change the Connection Pool Maximum Capacity on DMWServer
In the WebLogic Server Console:
Navigate to Services, then Data Sources, then lswdbDS, then the Connection Pool tab.
Change the Maximum Capacity setting from 15 to the number you entered (Edit setDomainEnv.sh, Step 12) for the maximum number of concurrent users during peak time plus 15%.
- Repeat these steps for these data sources: lwsdbDS (if not done
already), lswExtSysDS, lswdbRestDS, lswdbDfdDS, and lswdbExportDS.
- Set Maximum Capacity for the lswdbDfdDS and lswdbExportDS data sources higher than the DfdMaxThreadsConstraint and ExportMaxThreadsConstraint values (that were set to 20).
- Do not perform this task for the lswdbBC4JDS data source.
Parent topic: Upgrade to Oracle DMW 3.5
