Manage Work Areas in Oracle DMW
You can review Work Areas associated with a selected study on the Oracle DMW home page by clicking the Workareas for selected Study Spoked hub network.
Work Areas in Oracle DMW contain all of the object instances (Table Instances, Program Instances, and so on) which point to object definitions. Each data model in a study is associated with a different work area for each lifecycle. After selecting a study on the home page, you can click the Workareas for selected StudySpoked hub network. icon to load a new screen where you can view the Work Areas related to the selected study. You can search by data model name to find specific Work Areas using the search function in the upper right corner of the screen.
Clicking a row in the Workareas grid loads the instances in the Instance Objects Under: [Work Area Name](Version Number) section in the bottom half of the page.
