Modify the display order of product fields
- In the left navigation pane, click the Settings icon
). - From the Configure System menu, select Manage Signal Configurations.
- Select the signal configuration and, from its Row Action
menu (
), select Edit Product Fields. - In the top left corner, click Modify Display Order.
- To change the order in which fields display in the Edit Product Fields table and in the Add/Edit Product window, click a field and select one or more fields.
- When the fields are in the correct order, click OK.
Parent topic: Manage monitored products
