Step 3: Review product-event combinations for a product or multiple products
The Product-Event Combinations panel is a set of tables that represent views of the product-event combinations assembled from the current Refresh runs, as well as rows from previous refreshes which have either unreviewed alerts or comments.
You access the Product-Event Combinations page from the Investigate products in the Products table.
- Start with the Product-Event Combinations page
On the Product-Event Combinations page, you can review comprehensive product-event information and statistics for a single or multiple products. - Investigate product-event combinations for a single product or multiple products
The Product-Event Combinations page is a set of tables, accessed after selecting one or more products from the Products page. - Review product-event combinations from a multisource configuration
As an extension of interactive signal configuration, multisource signal configurations enable you to perform safety surveillance across multiple data sources.
Parent topic: Perform a Signal Review
