The Source Data section summarizes the recency of both data sources and signal management configurations
The Source Data section includes cards that summarize the recency of both data sources and signal management configurations.
There are three different types of Source Data cards. Each card type is represented by a different icon.
  • Data Source Type card Data Source Type: There is one card for each data source type that is published to you. Multiple data configurations are often from the same data source. Information includes:
    • Data source name.
    • Load Date: This date represents when the data was made available in the user environment. For local configurations, load date is the date when the configuration was created in the environment. For managed configurations, load date is the date the configuration was imported.
    • Either the Period, such as Year and Quarter, or the latest as-of-date for time-stamped configurations.
  • Signal Management Configuration card type Signal management configuration: There is one card for each signal management configuration that is visible to you, and that has been refreshed at least once.
    • Configuration name.
    • Last refresh date.
    • Either the Period, such as Year and Quarter, or the latest as-of-date for Signal Management Configurations based on time-stamped data configurations.
  • Signal Management Configuration card type Multi-enterprise signal configuration: There is one card for each multi-source signal management configuration that is visible to you, and that has been refreshed at least once.
    • The Data Source and Period for each of the configurations used in the multi-source configuration.
Selecting a data source card takes you to the Data Mining Runs page with the configuration filter set to the alphabetically first data configuration for that source.
Selecting a signal management configuration card or a multi-enterprise signal configuration card takes you to Signal Review with the signal management configuration selected.
