Delete a signal comment type
You can delete signal comment types if you have the Manage Signal Configurations permission.
If you delete a comment that is applied to a product-event combination, the comment remains visible when you view the signal history.
- In the left navigation pane, click the Settings icon
). - In the Configure System section, click Manage Signal Configurations.
- Click the Row Action menu (
) for the signal configuration, and then click Edit Comment
Types. - In the table, locate the comment to delete.
- Click Delete for the comment, and then click Close.
Parent topic: Manage signal comment types
