4 Initiate and monitor data mining runs
- What is a data mining run?
A data mining run is a three-step process: 1) extraction of data from source data; 2) application of statistical algorithms to the extracted data; and 3) generation of statistical values. - View data mining runs
The Data Mining Runs page provides information about existing data mining runs and enables you to define new runs if you have the required permission. - Data Mining Runs page
Use the Data Mining Runs page to extract data from source data, apply statistical algorithms to the extracted data, generate statistical values and manage specific data mining runs. - Create a Data Mining Run
- Manage custom terms
- Define subsets for an MGPS run
- View source data
- Manage data mining runs
- Data mining FAQs
This set of frequently asked questions relates to data mining and its applications in Oracle Empirica.
