Modify the display order of a product field's defined values
- In the left navigation pane, click the Settings icon
). - From the Configure System menu, select Manage Signal Configurations.
- Select the signal configuration and, from its Row Action
menu (
), select Edit Product Fields. - From the Row Action menu of the selected product field, click Define values.
- In the top left, click Modify Display Order.
- To change the order in which field’s defined values display in the Define Product Field Values table and in the Add/Edit Product window, click a field and select one or more fields.
- When the defined values are in the correct order, click OK.
Parent topic: Manage monitored products
