Example—Using a bypass list
The following proxy server configuration sends all outgoing traffic from the InForm Publisher application through port 9044 on 127.0.0.1, unless the endpoint address matches a regular expression specified in the bypass list.
If the endpoint address includes .oracle.com, it bypasses the proxy.
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<system.net>
<defaultProxy>
<proxy proxyaddress="http://127.0.0.1:9044" />
<bypasslist>
<add address="[a-z]+\.oracle\.com" />
</bypasslist>
</defaultProxy>
</system.net>
</configuration>
