Loading the InForm mapping table for a study
To load the InForm mapping table for a study for ODM Extract Publisher subscribers with the CTMS endpoint type:
- In the directory where you extracted the InForm Publisher product archive, go to the CTMS Mappings folder.
- Copy the mapping.xml file.
Note: Before loading the mapping.xml file, check if you must update it with the InForm codelist values. For more information, see the Integration Guide.
- Open the command prompt window and navigate to <InFormPublisher Installation Directory>/Bin.
- Run the following command:
CTMSMapping [path of mapping xml file] [tnsname] [trial user name] [trial password].
For example:
CTMSMapping C:\temp trials demo_user_id demo_password.
