EventPublishing
The EventPublishing command allows you to start or stop publishing events.
The Enabled attribute of the EventPublishing command is set to false by default. When this is false, the InForm Publisher service is running, but it does not try to publish messages based on the configuration.
When you have finished making configuration changes, set the attribute to PublisherAdmin EventPublishing Enabled="true" and restart the service.
