Configuring the Oracle Life Sciences InForm Publisher application using the Publisher configuration tool
The Publisher configuration tool is a user interface that allows you to modify the Oracle InForm Publisher configuration file.
The Publisher configuration tool appears when you click the Launch Config tool checkbox in the installer wizard. In addition, the tool, which is named PublisherConfigUI, is also located in the \Bin folder of the location where you installed the Oracle InForm Publisher software.
- Stopping and starting the Oracle Life Sciences InForm Publisher application
- Adding and configuring a subscriber
- Removing a subscriber
- Adding a Queueing Privilege Grantor user
- Adding a study to a subscriber
- Configuring a study
- Removing a study from a subscriber
- Loading the Oracle Life Sciences InForm mapping table for a study
